LED testing | on ElectriciansForums
Discuss LED testing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
pjcomp
Anyone yet come across a way of testing LED lamps apart from plugging them in? The old incandescents could easily be checked with a continuity test, but something similar for LEDs would help quickly separate whether a problem is with a lamp or lampholder, or check spare lamps in a box. I've tried the diode function on the multimeter but doesn't seem to work with a 240v lamp
pj
i've made up a 3ft. length of flex on a BS1363 with a GU10 holder on the other end. ssimplesss.
Reply to LED testing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
