Discuss LED tubes failure mode in the UK Electrical Forum area at ElectriciansForums.net
There is actually nearly nothing in the fitting at all. Just the lamp holders and a capacitor in parallel with the supply which is a good distance away.If you look at the fitting is there a component located along the location of the tube damage which runs hot?
The capacitor was originally part of the fitting to bring the power factor back to near unity, it has nothing to do with inrush currents.
they should be removed if the ballast is removed as one was to compliment the other.
It was not unwise, to be honest I don’t know why it might improve (reduce) the inrush. when it gets as deep as this into theory, I think tho only thing to do is say HELP! @Lucien NunesI realise their original function, but I did once find that turning on about 8 panels at once with 4 LED tubes each was tripping a B6 breaker, and reinstating the capacitors seemed to prevent this occurring. Was that unwise or messed up logic?
This further backs up my thought that I don't want to be messing around with converting fittings any more!
But in any case with respect to the tubes pictured above, it wasn't me what did it honest guvnor.....
An excellent idea, we rub the lamp and see if the genie is able to appear. I would completely understand if not, this may not be very high on the list for obvious reasons.It was not unwise, to be honest I don’t know why it might improve (reduce) the inrush. when it gets as deep as this into theory, I think tho only thing to do is say HELP! @Lucien Nunes
I popped in today and found another fitting with similar condition cable so it's indeed the right conclusion.The damage to the cables at the terminal block does not strike me as related.
Reply to LED tubes failure mode in the UK Electrical Forum area at ElectriciansForums.net
