I have a constant current driver for led lighting with an output of 1,05A at 150V dimmable down to 50%/525mA
I want to wire one LED spot with ~67V/1,05A and a series of LED strips at 23,5V/1,05A each, in parallel to the dimmer mentioned.
Basically I want to have a switch for the spot and one for the two strips, and running 525mA to 1,05A for every LED
Will this work as intened or is there something I'm missing due to my lack of knowledge
- TL;DR
- How does parallel wiring of LEDs to a constant current driver affect the current received by each LED
