Anyone havin any problems wiv leds lamps,jus installed load of 11watt led fitting wiv the driver built into the lamp ie 230v 11watt leds,these r controlled by a danler soft grid dimmer,& slave dimmer,so they can b 2 way from door to bedroom,major probs on actually fitting the dimmer onto a 35mm deep box all had to b changed to 47mm.Butt when no lamps r on, led flckers & remains on,this only happens on a singular fitting,or when 2 r switched together when a lamp blows.The rep as never seen this happen before & suggeste a resistor across lamp to resolve prob,there r over 200 lamps!!,On friday he replaced aLL LED LAMPS cos of problems of lamps blowing,this was suppose to of been all compatable wiv each other butt causing all sorts offa probs a nightmare.
