length of ring main circuit | on ElectriciansForums
Discuss length of ring main circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
davidjones89
what is the max length these circuits can go to in 2.5mm t & e ? 32a mcb with an installation method of clipped direct, just curious :confused:
When was the last time that you had a 100m drum???? i can garentee never!!
Next time you buy a fres roll of what ever size, use ur MFT to measure end to end resistance while on the roll and divide by the given value in the regs or osg, i can assure you it will come out to around 96-98 which means they are diddling us by a couple of meters a time!
What can i say, sad i kno
OSG 100msq. Very true some cable companies got in trouble some years ago by trading standards short a roll or two and see how much there profits jump.
i fancy paying it off the roll and then when its short i will get wholesaler to coil it back up and grovel to me for selling me less than i asked for!! if it is 100m then i donald ducked and will have a snotty pile of cable!!
Reply to length of ring main circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
https://www.amazon.co.uk/gp/product/B08CJ3VC79/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 I use this, current clamps go round each outgoing...
Haha yes, it is. Must be a northern expression. Have a Google 😂
