davetherave1979
Hi all what is the maximun length of a ring main in 2.5 te can you install as doing an extension in a bungaloe and the board is the other side of the building we going to be protecting the circuit with a 20amp mcb no larage loads as it feeds bedroom and lounges there will be no insulation on the cable we are looking at about 150m including all the drops and back to the board is this ok to do or should we install a 16amp mcb thanks
