Letting agencies | on ElectriciansForums
Discuss Letting agencies in the Business Related area at ElectriciansForums.net
Sanke
Hi all
I have been trying to get work with letting agencies in the local area but with not much luck. Just wondered how people usually approach this market ??
I send them a flyer and covering letter. Then give them a call a few days later. It also helps if you can find out the name of the Manager and address things to him.
If you use phrases like "I can ensure you and your clients continue to comply with all the relevant legislation with regard to the legal responsibility with rental properties".
This will usually provoke a call from them, because most haven't got a clue about the housing act, Landlord and Tenants act, and so on. Once they are aware you should get a bit of work. Also send them a copy of the ESC guide for landlords. It usually gets their brown juices flowing, if they are in the dark about things.
Cheers...........Howard
If you can get into a discussion with the manager you may want to talk about cashback or other incentives either personal or corporate in exchange for regular work. This can all be built into the cost once the relationship is established
agree ht,use of matchday box,holiday home etc,its how its done.if price and quality of work is what it takes we'd all be busy..
Hi
I have emailed them already Do you think a written letter is better ? What about personal visits with letters ?
run the risk of looking a tool, chances are the boss wont be there all theyll say is i'l pass it on.. after some awkward waiting if their with a client
Reply to Letting agencies in the Business Related area at ElectriciansForums.net
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
The last ICS I fitted hadn’t been registered when it left their factory… so just got a “device not recognised” error. Helpline fixed it over the...
