Levelling compound. Multiple layers
Hi.
I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our house. It's the first time I've done this particular kind of job and I'm quite please with the results. It's a fairly big area at 21 m2. (We'll, I thought it was big.
) We intend on laying laminate flooring in this room and understand the importance of having a flat surface beneath the planks.
There are a few minor imperfections in the screed. A few dips here and there. Most only a millimetre, others as much as 3mm. Is it acceptable to smooth out these dips with a second layer of compound. Not over the entire surface, just where the dips are?
I understand that someone may just suggest that I lay the laminate and that 3mm is acceptable, but I would still like to know if multiple layers is acceptable. And if so, what is the best practice for doing so.
Many thanks
Levelling compound. Multiple layers for the Original Article on Tiling Advice Forum
Hi.
Many thanks
