Lewden MCB compatibility | on ElectriciansForums
Discuss Lewden MCB compatibility in the UK Electrical Forum area at ElectriciansForums.net
timhoward
Broke Internet
Supporter
Solutions
Oswestry
Hi all
I can't remember if the current range of Lewden MCBs fit these boards? It's to supply SWA so RCBO not needed.
Thanks for any help.
[ElectriciansForums.net] Lewden MCB compatibility
Yeah, be reight.
If you're after something a bit more than that: Circuit Protection FAQs - https://www.lewden.com/faqs/circuit-protection
You'll probably find the web page is broken, in that if you click on a question, the answer doesn't pop up. If you try to "print" the page, though, and look at the output (as a PDF or a print preview), it expands all the questions and answers.
Reply to Lewden MCB compatibility in the UK Electrical Forum area at ElectriciansForums.net
Blue & black are there, just need red and yellow. I am sure that elsewhere in the world they are needed...also red has made a come-back in Table...
Or even fit a 2module RCD in the CU, if there are two spare ways unused. Some might disagree, but I have no problems with fitting 'other makes'...
