Lewden | on ElectriciansForums
Discuss Lewden in the UK Electrical Forum area at ElectriciansForums.net
sparks1234
Hertford
Evening guys
We are carrying out a small install and we need a bit of RCD protection on some circuits for which I was going to install some RCBO's
The dis board is a Lewden which was preinstalled by others, never worked on that make since the old screw cap sockets
Now, the RCBO's turned up, marked as RCBO but they look like any other companies RCD's, i.e. they have the phase and neutral feeds one side and the load on the other side rather than a flylead for the neutral on the neutral side, anyone come across these before? and, does anyone know if they do a "proper"RCBO
Reply to Lewden in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
