H
Hogan
Hi,
just wondered if anybody has any thoughts on the following
i have replaced some tubes in flourescent fittings, the tubes are failing after 4 months. They are dimmable fittings and apparently there is a requirement to turn off this facility inside the fitting when you change the tubes. The fitting resets itself back to dim mode after a few days.
My view is its a maintenance issue and I should have been made aware of this but the client wants the lamps replaced again free of charge.
Am I liable as no detail or information on the fitting was issued and the request was to replace the tubes ?
