Life Safety Services Generator | on ElectriciansForums
Discuss Life Safety Services Generator in the UK Electrical Forum area at ElectriciansForums.net
M
Marxman99
Hi, I have a 50kva generator, it will only be used to supply the life safety services loads (water pump, vent openers, vent fan). Each item is connected to an ATS, one supply to the ATS is from a ‘normal supply’ distribution board, and the other supply is from a generator supplied distribution board. The generator is positioned on the ground floor of the building.
My question: Do I need to provide a separate earth rod connected to the generator?
Thanks for reading.
Reply to Life Safety Services Generator in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
if the 3 spaces with charge points are always allocated to the same 3 flats, surely the easiest way is to run the supply to the load side of the...
