Light fitting DIY | on ElectriciansForums
Discuss Light fitting DIY in the Lighting Forum area at ElectriciansForums.net
30min job for an electrician.
diy could take from 30 min to 5 hours depending on your
knowledge,
experience,
and if lacking in either of those 2, luck.
Welcome to the forum mate.
As above. its hard to say how long it will take to do the job.
Take a pic of the light wiring you are going to swap it with. This should give us more of a clue.
Switch off the power to the lights at the consumer unit before you go messing with it though.
The fitting looks somewhat like a standard style that has not been quite completed before being sold. Usually the various L & N connectors are already pre-joined in some crimp/twist connectors, not all just dangling loose. And usually the large E ring terminal is already fixed under one of the nuts holding the lighting bars/supports, rather than also left dangling. And a bit curious to have each set of wires loosely wrapped with yellow/green earth tape. It all adds up to lots more possibilities than normal to get things wrong.
Reply to Light fitting DIY in the Lighting Forum area at ElectriciansForums.net
That does help, it shows that the problem is almost certainly in the way it is connected and not a problem with the fittings.
davesparks
It’s getting to the point where full LED replacement is cheaper than spending time on testing and possibly replacing parts.
