Light fittings | on ElectriciansForums
Discuss Light fittings in the Australia area at ElectriciansForums.net
W
Warriors2008
Hi all,
New to the forum and this may be a simple question for someone but here goes. I have two lightfittings in my kitchen, one of which is permenantly live I.e the lamp is lit all the time. I measured the voltage and it is Reading 293volts on the loop and 49 volts on the switch side when switch is off! Any ideas guys? Thanks in advance.
Reply to Light fittings in the Australia area at ElectriciansForums.net
As said, looked like there was enough cable slack to correct direct and avoid fitting the wagos in ceiling void
Take it off, pull the cables through the new board and refit light once plastered.
