Light Fixture and Fire Alarm question please | on ElectriciansForums
Discuss Light Fixture and Fire Alarm question please in the UK Electrical Forum area at ElectriciansForums.net
vanessap
Brighton
Hi All,
Please may I ask if light fixtures must now always be fitted by an electrician?
also for domestic homes, is it okay for there to be a battery operated fire alarm and carbon monoxide alarm or should there also be a heat alarm and all three hard wired in?
Thank you all so much,
Vanessa
Re your first question: no (but competency and ability to fit correctly is important)
Re your second question: It depends, but where I live, in Scotland, you would typically have smoke alarms in designated areas, heat alarms in designated areas and CO alarms in designated areas. They do not require to be hard-wired, but the smoke and heat alarms must then be linked by a radio-module and be powered by a 10 year lithium ion battery. Currently, CO alarms do not require to be linked to the others, but if battery-powered they also need to have 10 year batteries to meet current Scottish regs.
A somewhat truncated answer as there are many things to consider, but actually there are many sources of information on the smoke/heat/CO alarm scenario available online, and reading some of those will certainly assist you.
Thank you so much @pirate
Still have to be hardwired here (obviously with battery backup).
Reply to Light Fixture and Fire Alarm question please in the UK Electrical Forum area at ElectriciansForums.net
Heat & Carbon monoxide detector recommended for a kitchen.
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
