light fixture rewiring | on ElectriciansForums
Discuss light fixture rewiring in the DIY Electrical Advice area at ElectriciansForums.net
Steven Sinclair
So I bought a light fixture from a shop which runs a 60w candle bulb. I have rewired it using a block to connect it to a plug.
All the wires are connected to the correct nodes within the block and plug.
Unfortunately I am receiving no light from the bulb when switched on.
Any advice is welcome.
Hi Steven, welcome to the forum :).
Do you have any electrical experience, test meters etc (Your profile hasn't been filled out)... this will help us with how we respond to your query.
Why have you had to rewire it. Shouldn't you take it back to the shop and say it didn't work?
I wanted to convert a wall light into one I can use on a plug.
Why did you not buy a light with a fitted plug?
They didn't have one that I could use above a dartboard
Photos of the wiring connections at the plug and the light fitting would help.
Reply to light fixture rewiring in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
