Light for loft | on ElectriciansForums
Discuss Light for loft in the Electrical Tools and Products area at ElectriciansForums.net
B
Bright.Spark
Can anyone recomend a good light when working in a loft? Im fed up with working off a torch and nearing coming through the ceiling! It can be mains powered or battery opperated but Im looking for something that will light the whole loft. Thanks guys.
I use a IP65 4ft tube fitting when in lofts or dark areas, connected with flex to a plug top and suspended by bungees. find they spread light across the whole area better than anything else such as halogens or normal lamps which are more directional!
I like that idea, I may have to knock something up in the shed later. Have used halogen floods and standard clip on wanderlights, but I always seem to be working in my own shadow because of the directionality (?) of them.
Got a head torch! look like a **** but it works a treat .............dont forget to take it off.
they now do a one that clips to front of a baseball cap as well
For a loft I would also go with a 5ft double fluorescent as suggested above by telectrix. Cheap and cheerful to buy, low maintenance, cheap to run and it's linear nature helps keep shadows to a minimum. If you use a double then lamp failure doesn't leave you in total darkness.
Reply to Light for loft in the Electrical Tools and Products area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
