light in marquee | on ElectriciansForums
Discuss light in marquee in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
gdlc
I have been asked to put up a light (110v) in a marquee, generator excisting, basically i have to plug it in, job calls for a cert don't see i need to cert any idea's
Reply to light in marquee in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
and sometimes if the drainpipes have been up a while the brackets can be brittle from sun damage and as you say they are nailed on which can be a...
