Light on shop front | on ElectriciansForums
Discuss Light on shop front in the UK Electrical Forum area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Guys
You may be able to help me out.
We've inherited a job from previous Electrician. Light over shop front sign needs replacing.
Whole unit soaked through and cant be fixed. Did have diffuser but this has also come off now and had it
Any ideas how I can get direct replacement for something like this ?
If not poss did have an idea of trying re-use the existing enclosure and fit some IP rated LED strip in a profile !? maybe
Thanks Sy
[ElectriciansForums.net] Light on shop front
Is there a brand on the fitting anywhere?
Local wholesalers not help?
It might just be a regular fluorescent fitting inside the circular enclosure…. Which suggests you could get an LED equivelant to fit.
Get the fitting down, dismantle and see what can be done
Thank you... I'll get up there have proper look, this was just a 1st glance !
Reply to Light on shop front in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
