C
chrisgc
I have a problem with one light that depending on which way its wired up will either stay on or not come on at all.
I have attached a pic (poor quality) it does look a mess but this is only temporary by the way.
The pic of the cables is as follows:
Cable with no tape = Switch wire
Cable with white tape = Power
Cable with Yellow tape = loop to next set of lights (which works fine)
Cable with red tape = loops to other set of light (light at end does not operate properly with pic of light)
Red taped cable goes over to another light which is operated via a switch (cable with no tape) and the switch should operate this lamp holder as seen in the pic BUT also the red taped cable which loops to another light feature.
For some reason when I wire the red taped cable to the next light it either stays on or depending on how I wire it at light end it may stay off.
Hope you guys can follow my writing and really hope that a solution is found as its been really bugging me - It has worked in past but I was silly enough to forget to take a pic.
Chris
Chris
