Light switch change advice | on ElectriciansForums
Discuss Light switch change advice in the DIY Electrical Advice area at ElectriciansForums.net
Dannydm1
Hi, I'm currently updating some light switches, I all one gang switches, two of which are two way, and the third is a one way switch.
i have purchased some one gang intermediate switches, am I ok using these? As they are different to the switches I have at present..... The ones I have now have a com and l1 + l2
the new switches have l1, l2, l3 & l4
Hi Dannydm1, welcome to the forum.
You will be graded to DIY status and thread relocated to the DIY section when Admin' are next on line but to ensure your not waiting around we have approved it to run in the main forum for the time been. Thankyou.
Just ignore L4, intermediate as far as i understand it is normally used for 3 switches controling one Light bank.
So L1 say Linked to L3 while L2 is Linked to L4, then you switch it, then it becomes L1 to L4 and L2 to L3
In Electronics a Kind of FLIP FLOP Switching.
So L1 L2 as normal and use L3 as the Common and Ignore L4
[ElectriciansForums.net] Light switch change advice
People think better of you if you have PICTURES
Great, that's done the trick on the 2 way switches. Any advice in the one way switch, which just has a wire going into l1 and a common wire? Where should they be in the intermediate switch? Thanks
common L1, SW L2.
Reply to Light switch change advice in the DIY Electrical Advice area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
