Light Switch Fitting | on ElectriciansForums
Discuss Light Switch Fitting in the DIY Electrical Advice area at ElectriciansForums.net
Swanwick
I need to add a chocolate block to a light switch for an earth, what amp should I use please
Reply to Light Switch Fitting in the DIY Electrical Advice area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
It could be a slave switch where you would have a L in and a common wire out to a master switch.
sadly not modern, 15th century but rewired about 15 years ago.
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
