Light/switch fittings | on ElectriciansForums
Discuss Light/switch fittings in the UK Electrical Forum area at ElectriciansForums.net
Halifax
Hi guys, hope all is well.
Getting hallway and stairs replastered/skimmed, do the light switches/light fittings need removing altogether for it to be replastered or is it a case of simply just unscrewing the fronts?
I know they might be silly question to some but just want to make sure.
Thank you
all depends on your plasterer. usually the switches & sockets can be pulled forward (depends on the cable slack) enough to plaster around, there are magic things called yoozy boxes that can be fitted enabling the muck spreader to make a neat job without the usual trick of gumming up the accessory with said muck. They are reusable so you can do a couple of rooms at a time.
[ElectriciansForums.net] Light/switch fittings
Thank you for the reply, much appreciated.
What I forgot to add btw is that I've been told that the ceiling needs overboarding due to damage when the loft was getting insulated, there is a light fitting at the top of stairs near where the damage is, do you know what would entail wiring wise regarding this?
Take it off, pull the cables through the new board and refit light once plastered.
Reply to Light/switch fittings in the UK Electrical Forum area at ElectriciansForums.net
As said, looked like there was enough cable slack to correct direct and avoid fitting the wagos in ceiling void
