Light switch in bathroom | on ElectriciansForums
Discuss Light switch in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Doncaster
I am not an electrician but I had my bathroom re done and a electrician replaced my light pull cord with a switch it is 1.4m away from my bath I was told this was ok. I have had another electrician come out for another job and has been in my bathroom and said it needs to be a pull cord and isn’t allowed
A plate switch is permitted as long as it is greater than 0.6m away from the edge of a bath or shower. However the rooms environment al conditions and use have to be taken into account - it might not be a good idea to use a plate switch in a bathroom that suffers with high levels of condensation or humidity for example.
A plate switch in a steamy bathroom never sits well with me. And far too easy for someone dropping wet through to operate it.
I say minimise the risks.
Nothing at all wrong with a plate switch in a domestic bathroom. There is, and never has been, any regulation preventing it. The original regulation was that it shouldn't be placed within reach of a person using a shower or bath, and this was relatively recently changed to the 0.6m regulation mentioned above (which in practice, is much closer than permitted by the original reg.)
I have never fitted a cord switch in any bathroom or shower where the regs could be satisfied by a plate switch, and have NEVER had a single instance of a customer complaining of even the mildest electric shock from a switch.
I have, however, had several cases of other electricians, like in the OPs case, complaining that it's not allowed, including the QS of a large local electrical contractors. This happened on the single occasion that I've had to use a third party to sign of a new build to the local authority, after a state of war had existed between the builder of the property and the LA.
If a switch is positioned just outside a bathroom, it will have the benefit of being more protected from a poorly ventilated room, but will not stop some dope opening the door and using the switch with wet hands.
And will result in some idiot turning it off for a prank while the room is in use.
How often does anyone get out of the bath or shower without at least whipping down a bit to stop dripping water all over the floor, damp hands on a light switch may be, but dripping hands ? not forgetting operating the light switch to turn it off means you are ready to leave the room by witch time you have dried off.
It's more the other way around. If it has got dark and someone switches the light on to get dried.
Not saying it shouldn't be allowed, but it seems a sensible thing to minimise the risk and either use a pull cord or maybe a kinetic switch or similar perhaps.
.......means you are ready to leave the room by witch time you have dried off.
More often than not, the switches I fit are multiple ones, for more than one light and to control an extractor fan. This is the case in my own main bathroom, and occasionally I step out of the shower, realise I forgot to turn the fan on, and switch it with a dripping hand. Never a hint of a tingle.
Someone getting in a bath when light is good, spending a long time in the bath until ambient light has decreased and whipping a door open to switch the light on before continuing to get dried etc.
Most normal people wont, but you cant fix stupid with some.
Edit: Not meant to be aimed at you Brianmooore :)
Someone has been in the bath so long it has got dark. ?. Oh of course the 101 candles have gone out as well. ?
This could run and run, there are obviously two camps on this, lets all agree our own preference is the best way.
Yeah I get your point. Although to say something is OK because you've never had a tingle is not a convincing argument ?
Reply to Light switch in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
