light switch old wiring help | on ElectriciansForums
Discuss light switch old wiring help in the Lighting Forum area at ElectriciansForums.net
uk
hi could some one please help me with the wires on this light switch please i need to change it to a new one
any help would be apreciated thanks
  • [ElectriciansForums.net] light switch old wiring help
Are there terminal markings at the switch for the red, yellow and blue wires?
Is there earth wires attached to the back box?
Is there any marking moulded into old switch?
I would think the one switch with red, blue, yellow… put the red into Com, and the yellow/ blue into L1 and L2 of the new switch.
On the other half, one red into Com, other red in L1 or L2… doesn’t matter which.
The new switch is simply 2 separate switches on the same plate.
hi the only marking are the middle with com and the back box are earthed i did change the one upstairs yesterday wich is a single switch were there was 2 red wires together red and yellow together and the blue on its own if that helps
As with the drawing above.
The red, yellow and blue wires, blue into COM, red into L1 and yellow into L2 (it is odd red isn't into COM on the old one but doesn't matter).
The two reds, one into COM the other L1, doesn't matter which way around.
You also need the earths connecting to the earth terminal on the new switch.
thanks very much for taking time out to help it worked a treat much apreciated
Reply to light switch old wiring help in the Lighting Forum area at ElectriciansForums.net
Here are photos of the power supply unit, somebody told me I need a new transformer? Many thanks in advance.
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
