Light switch or pull cord in WC | Page 2 | on ElectriciansForums
Discuss Light switch or pull cord in WC in the UK Electrical Forum area at ElectriciansForums.net
Clocks
London
Hi all
I have built a WC with a basin for hand washing. There is no shower or bath in there, just a toilet and basin.
I don’t want to install the light switch outside the WC and don’t want a pull cord inside. I would like to install a wall switch on the inside, which would be located to the left side of the basin approximately 300-350mm from the tap. I have been told that this would not be permitted under building regulations and that electrical sign off would not be given. Any guidance on this would be greatly appreciated. Thank you.
When you say 300mm from the tap is that horizontal or vertical? If horizontal what height did you intend fitting the switch?
Horizontal. Height would be standard height off the floor.
[automerge]1579544013[/automerge]
Use WiFi activated spot lamps then only you, your wife and the cleaner will be able to switch them on!
? that’s an option!
Have I missed something here? I thought in a bathroom, no switch gear is permitted within the zones? A pull cord switch or switch outside the zone is the only thing permitted?
it’s classed as a special location isn’t it?
It's not a bathroom location as per section 701 that is in question here. It's a WC room.
Yes
the first sentence of the original post
"Hi all I have built a WC with a basin for hand washing. There is no shower or bath in there, just a toilet and basin."
Sorry, my bad - it was late!! In that case, I would treat it similar to a kitchen with the switch at the relevant distances from the basin and at the correct heights
Reply to Light switch or pull cord in WC in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
M
Bathroom first/second fix plumbing costs Hi all, I just got a quote for bathroom and WC plumbing LABOUR only first and second fix ÂŁ3850 for the...
midaslegend
M
