Light switch question | on ElectriciansForums
Discuss Light switch question in the Lighting Forum area at ElectriciansForums.net
uk
Can I wire a immersion heater switch to be a normal light switch which shows the garage light is on by the LED on the immersion heater switch
Garage light switch is in the kitchen
[ElectriciansForums.net] Light switch question
That's a two-way light switch (there must be another switch also controlling that same light)
An immersion switch will be double pole but not two way.
You can make up a grid switch with a 2way switch and an indicator light, connecting the indicator across the grey and black wires.
However, the light will indicate when the garage light is off rather than on, and there's a possibility of 'strange' effect if the garage light is LED.
Reply to Light switch question in the Lighting Forum area at ElectriciansForums.net
Indoors? Is the rcbo dedicated to this, or is it an up or down lights rcbo? 6A? Or something else? I'm a bit surprised if it's a current surge...
Definitely get someone in - it should be a very quick fix. I was also worried that this may have been a boiler timer and not capable of handling...
nicebutdim
N
