JoeFixes
Good Morning,
I apologize if this post is out of context, I could not find a better fit for it.
I am replacing a light switch in a Hyster S40XL forklift. The light switch turns on the spot light in the front of the lift as well as the red light in the back.
The new switch I have is a pull-out type with two settings....you pull it out half way for one setting and pull it out fully for the second.
I've attached some photos of the old switch while it was still attached to the forklift and also the new switch. There are four wires total.
I could use some help in determining the proper wiring for the new switch.
Thank you in advance.
JoeFixes
JoeFixes
