Light under bathroom vanity? | on ElectriciansForums
Discuss Light under bathroom vanity? in the Lighting Forum area at ElectriciansForums.net
Ruthio
Stamford
Hi. I am looking to put a warm led light under a bathroom vanity. I don’t really want a cheap battery powered job from amazon. ideally I’d like one with motion sensor - im Finding it difficult to find anything with the correct rating... any recommendations gratefully received. Thank you
Reply to Light under bathroom vanity? in the Lighting Forum area at ElectriciansForums.net
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
