G
gorilla
Hi Guys
Looking for a wee bit help here to diagnose a lighting problem that I have.
My room light (just had to be mine) is playing up. When switched on it sometimes flickers as if there were dips in the electricity supply. I know that the supply is good as I do not get any issues with any other appliances or lights in the house.
Earlier on it went out completely so I done the usual checks to see if the breaker had tripped, everything was fine at the CU. I then went on to check for loose connections both at the switch and at the light, all connections are fine.
I have had this issue for ages and thought a few weeks ago I found the problem as the light pendant had a loose Neutral, caused by the wire restrainer clip snapping. Fair enough had it happen many times before with other lights and that so I replaced the full pendant. I thought my problems were over, but no.
About two years ago I changed the light switch when I was decorating. The problem didn't start until 3 or 4 months ago so that potentially rules the switch out.
I am using a energy saver bulb, so thought that was the issue so changed that over to another lamp and it is fine, also put a standard bulb in and I still get this problem.
I don't have a clue what to do now, I just can't explain this.
Anyway since I am here and with this issue I take it I will need to do some work on it so have thought about adding in a second light switch over at my bed, to encourage my lazyness. Just a standard 2 way set up but was wanting to know if it would be possible to do this with a pull cord. Reason I want a pull cord is it is going to be easier than dropping cables down the walls and then hacking away to fit any switches in flush.
So can I set up a 2 way switch using a pull cord switch and standard light switch?
