Hi guys, I am adding a lighting circuit to a Ring main 32 A. Can I just use a 6A MCB type B in a box on DIN rail to supply my lighting. I am using 1.5mm cable after the 6 A MCB.
Thanks for your advice!
Discuss Lighting circuit supplied from a 32A ring main socket. in the UK Electrical Forum area at ElectriciansForums.net
Yes, it doesIt depends on whether the ring circuit is supplied through an RCD.
Feed the lighting through a FCU with a 5Amp cart fuse and, forget the 6A breaker and enclosure,My issue is though in terms of short circuit by the lght, both the 6A mcb and the 32A mcb trigger. I would rther the lighting mcb to trigger only. shall I change into a rcbo o a different cb?
good alternative!Feed the lighting through a FCU with a 5Amp cart fuse and, forget the 6A breaker and enclosure,
good alternative!t.The only safe alternative I think.
I called it first ??good alternative!
Reply to Lighting circuit supplied from a 32A ring main socket. in the UK Electrical Forum area at ElectriciansForums.net
