lighting circuit that trips | on ElectriciansForums
Discuss lighting circuit that trips in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
feebs73
Hi can any one help?
I have a customer that says his lights keep tripping out when the shower is on in the ensute and bathroom at seprate times, the wiring is 4 years old the lights are mains gu10 (not ip rated) there is a inline fan with a lv light in it, there is no sign of moisture and no sign of burning cables, i have taken the lights out 1 by 1, also taken the fan out aswell, ended up with none connected, then the mcb stays on, does anybody have any clue?e
Many thanks
Feebs73
If the MCB is tripping then there is a significant short somewhere; if the IR tests have been done on all conductors and are OK then the problem lies with the lamps or the fan, try a continuity test on the fan and the lamps and see if the values are very low.
Yeah i have thought of that, but as i am not 100% that is the answer, and the cost for the customer if i am wrong.
Thanks anyway.
Reply to lighting circuit that trips in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ok I’ll try this when I’m down
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
