lighting circuit with broken cpc continuity | on ElectriciansForums
Discuss lighting circuit with broken cpc continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
F
freedomrun
Domestic lighting circuit with two luminares and associated switches where a cpc is present, but no continuity - all other points have cpc continuity back to the CU. A CU change at this property is requested and i cannot locate where the cpc to these two luminaires and switches has become disconnected. Any advice on what i should do now regarding testing on this circuit, before i go any further. The owner does not want me to remove any flooring and no access to the loft space.
Reply to lighting circuit with broken cpc continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
