lighting circuits | on ElectriciansForums
Discuss lighting circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
birmingham
hi guys is it true that when doing a eicr lighting circuits that are not rcd protected now have to be a code 2 ?
thanks its just because i done a eicr the other day and was told by my nappit mate that where before it would be a code 3 it is now code 2 and the test had failed
I suppose I might give it a C2 (or even a C1) if the cables were run at a depth of less than 50mm in an area marked, "Nail gun testing area: all nail gun testers must ensure they are holding the supplied extraneous-conductive part with one hand and the nail gun with the other when testing the nail gun."
Maybe NAPPIT's own rules/regs?
I'm with NAPIT and am not aware of them saying this, and I normally scan through any emails they send out. I would ignore that kind of 'guidance' anyway if they did.
Reply to lighting circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
