lighting circuits... | on ElectriciansForums
Discuss lighting circuits... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
Benn
Lighting uhh-ohh :(.
In a rewire I'am doing, i need to wire 2 lights switched off/on at the same time from 2 different switches. I think im correct in how I propose to wire it but i just thought i would check.
[ElectriciansForums.net] lighting circuits...
Would this work as i proposed above. One switch turns on both lights then at other end of corridor another switch turns off both lights?
Thanks for your help.
Benn
I was just wondering because I thought maybe I'd need a switch cable between the light and switch on the right. I work for a building firm, which has a couple of sparks but we are never on the same jobs so I couldn't confirm it with them. Thanks anyway.
Reply to lighting circuits... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
