kitchen /dinning room , id be tempted to go for warm white fire rated fitting with led bulb in what price roughly are you getting these fittings for and if money wasnt the question would you just go for the full jcc fitting...
Discuss lighting colours in the UK Electrical Forum area at ElectriciansForums.net
Take it you mean a bathroom light with a combined extractor fan.can the carbon minoxide be battery powered, would they link into heat detectors???
also have you ever seen the shower room lights with vent built in, do they require a perm live aswell as switched live ??? cheers tb
Not here they don't, not just yet anyway.Building regs would require a carbon monoxide and heat detector in a room with a log fire.
Lever clamp can take flex as well as rough stranded and solid cores, push fit can only take solid cores and rough stranded, not flex.also ive never used the wagos, can the lever clamp take flex and solid cores ---
Reply to lighting colours in the UK Electrical Forum area at ElectriciansForums.net
