Lighting control system options | on ElectriciansForums
Discuss Lighting control system options in the Lighting Forum area at ElectriciansForums.net
Hertfordshire
Morning. I'm looking for some advice. I was a NICEIC QS about 8 years ago, but I left the industry and so I'm not across the new market products.
Around 6 years ago I rewired my house and I prepared the wiring for a Rako system where is wired all switch lines back to a central hub next the consumer unit and then wired out data for the local scene setting panels (switches all of which in deep single boxes). I ran out of money before I could install the Rako system, so we have been going under the stairs to turn on the lounge and kitchen lights ever since 🤦‍♂️!!
My question is, which systems should I now consider that would work with this method of wiring? I am not opposed to Rako, but the game moves on and maybe there are other reliable systems that might even be more affordable.
And whilst i'm on, i'll take any recommendations of RGB strip and profile, again, wired back to a box ready for drivers (not these plug in systems)
Thanks in advance
So, you've got all (or ccts in questions, anyway) the lighting outlets wired as single radials back to a central point - hub / spoke fashion, and the switch plates are fed using a Cat5/6 data cable, again all going back to the same central point??
Yes sir. Exactly that. Probably got about 8 individual switch lines. I could bunch to slim it to 6 if needed
Reply to Lighting control system options in the Lighting Forum area at ElectriciansForums.net
Try a new setup, strip may be damaged, cannot really offer much from the details I'm afraid. Did you cut when live? Transformer may be damaged...
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
You are quite welcome my friend and good luck. I wasn’t trying to insult your intelligence and sorry if it seemed that way. Have a great day
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
