Excuse what may be an obvious question here fellas, so I apologise, but I'm having a real brain fade after a bit of a trying couple of weeks at work (other work, not 'here')......A customer has requested that I install 3 x 12v downlight fittings to a small ensuite. My question is that as that particular circuit has no CPC, can I fit metal-bodied 12v fittings as the transformers/connections will be away from any point of contact (in loft space) in the ensuite?
My thoughts were that as the customer would not be able to get anywhere near the transformers at the same time as the metal fittings (without dropping them out of the ceiling first, of course!), and that as the transformers would be away from the fittings, any fault would be no more than 12v, then it could be ok to fit them.
Obviously I have explained the benefits of re-wiring that circuit/adding a separate CPC, but my words are falling on deaf ears.
What do you think folks?
