C
cybermonkey
Hi there and hope you can help with this question. I've been given a rather random electrical job, I need to install the lighting on a number of professional free-standing makeup mirrors and I'm having trouble sourcing the correct fittings.
I want to install 8x100W lamps in each wooden frame through pre-drilled holes, and in the holes i'll fix the brass pendants and daisy chain these together to a switch and then to the socket. To hold the pendants in place I want to use a flanged lampholder with fixing centres in the flange so that I can push through the holes and attach from the back of the frame, then attach the pendant to this, add a brass decorative cover on the front, and then attach the lamp.
I've had a look around and I can't seem to find anywhere that sells these fittings as a kit. Can anyone point me in the right direction?! Thanks
