T
tricks343
Hi everyone, I hope all is well
Today I was installing some new IP65 Non-corosive twin flourecents. They where in exchange for similar lights.
The wiring was done (or at least added too) by some DIY know it all.
While I was installing one of the lights I had to make adjustments to the cable. The circuit was fed at switch And in the fitting the Switch was joined by a connector block, extended to reach the fitting terminals and also feed the next light in the circuit, however also from the fittings attached terminal block was another light being fed.
In total 4 cables 3 in one block, two in the terminal block
The loose block that was used for extending was covered in insulation tape which had become very sticky
I reterminated it all. Not particularly happy with the wiring but to me it's acceptable. I didn't apply insulation tape because I can't stand it when it's done.
Them Mr know it all turns up. He said get some tape on it and push the block into the ceiling at this point a debate broke out. Because even though it's advised to keep cables to a minimum in such a fitting pushing a connector block into the ceiling is not allowed and to be honest I'd rather not put a maintenence free Jb on it then in to the ceiling as I'd rather have any joint like that accessible even if such actions are allowed.
What are your opinions?
Firstly, wrapping the joint in a tonne of insulation tape when its enclosed.
Secondly, pushing joints into a ceiling regardless if it's in maintenence free containment.
And finally, DIY "experts" who always think they know best!
Thanks guys!
Thanks guys!
