M
MJM
Hi,
I want to put a light in my shed. I have a fused spur off the ring main in the conservatory that runs to an outside socket (no longer in use).
Am I ok to put another fused spur off this with a 5A fuse in for my light circuit in the shed?
It will be done with SWA cable, clipped in free air and then buried in concrete to the shed.
What IP rating would the luminaire and switch in the shed have to be?
Do I need a junction box in the shed for the SWA to run into some 1.5mm twin and earth? If so what IP does the junction box need to be?
Also is this notifiable, as in does it class as outdoor lighting?
Thanks for any advice.
