Hi folks, I've come here for a little help, after switching off my downstairs lighting circuit to change a light switch and then turning it back on to find that the back half of the house is now in darkness.
Basically, I wanted to add a WiFi switch for control of the living room lights, so switched the downstairs lighting circuit off on the RCD/fuse box and then unscrewed the light switch fitting. At this point the wife strolled back in and suggested doing the washing up, so I had to turn the lighting circuit back on so we could see in the kitchen. I hadn't yet disconnected any wires in the light switch, but had removed one of two living room ceiling lights to replace it. All wires for this light are exposed, but I made sure that none were touching.
The circuit breaker switched back on and stays in the "up" position, but none of the kitchen or dining room lights work. Only the front half of the house, including the remaining ceiling light in the living room. All other switches are in the "up" position too, so nothing has tripped.
What is likely to be the problem, and how do I fix it?
