lighting on 3 phase | on ElectriciansForums
Discuss lighting on 3 phase in the Talk Electrician area at ElectriciansForums.net
benji
north east
keep coming across switching probs.where you have large area's of lighting spread across three phases,we used to use barrier sw/boxes apparently we don't need them now just stick a 415v label on the switch.Then you get the problem with multi gang switches with say three metal conduit drops and if your not looking somebodies got switch wires & phases down different conduits
would welcome any thoughts on the above
yours benji
happens all the time they're either marked or its belling out time got a nine gang to deal with at the moment 5 circuits 8 switch wires
did i forget to mention three are two way??
Reply to lighting on 3 phase in the Talk Electrician area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
Sooo the client has accepted that we don't want to be fraudulently taking electricity so that worry is out of the picture. But now basically the...
5K
