N
Newbie90
Hi all,
I changed a light pendant at a friends house and found his lighting circuit in the extension (2 lights) is wired off the ring main!!
I have looked everywhere and cannot find a FCU, so can only assume it is in a junction box under the floor!
Carpets have recently been fitted so bit of a nightmare lighting floorboards and tracing. The cable to the light switch is in 1.5mm t&e.
I can replace the light switch with a FCU and put the light switch beside it, so it is fused down. Just wanted to know if this is ok as the cable supplying the FCU would only be 1.5mm.
Is there a risk of that cable overloading as it would be connected to the ring by a junction box (I assume)?
