I'm assuming this message needs manual approval as I'm unable to post in the DIY section I thought I would put it here with the idea it may be moved over to the DIY section. so at tleast the question is asked
In my kitchen there used to be two lights running of a double light switch as you enter the kitchen however this was changed some years ago by myself so each light ran individually off an individual switch from different place in the kitchen, simple enough.
However this was changed a while ago when one light was removed completely ( A centrally sittuated light installed ) and the wires at the second ceiling rose boxed / blanked off and pushed into the ceiling resess and the light switch was also blanked off as it still has power going to it as it was easier to do that than remove the existing wire.
Anyway here's the question
I have recently built a new pantry where one was removed many moons ago, which would benefit from having a light in.
( Edited because I realised the problem with my first idea )
The blanked off light switch which is OBVIOUSLY Perminant Live and switched live CANNOT be run up to the new rose as there would be no neutral Drrrrrrr note to self.
So am I left with the option of running new wire from the old ceiling rose to the new one ( which will involve damaging the ceiling ( just been replaced so not a good option. )
Run a new wire from the consumer unit to a new switch then a wire from switch to new rose which means I dont have to worry about the switch wire as the new switch only becomes live when the switch is flicked ( As the consumer unit is in the pantry this is not a biggy to do unless I forgot something with this option??)
Or just connect a light fitting to a plug and use a switched plug in place of a light switch ( Not ideal.
Any advice welcomed
Cheers Bil
Any advice welcomed
Cheers Bil
