Lighting ring issue | Page 2 | on ElectriciansForums
Discuss Lighting ring issue in the Lighting Forum area at ElectriciansForums.net
Are you assuming they are live from the wire colours? You can't. Electricity does not know what colour the wire is.
What you have is a typical loop in at switch circuit. The 2 wires in COM are live in and live out to next switch. In L1 you have a switched wire to the light. If the light stays on the switch is short circuit. This assumes you have found the right switch.
My 2p worth: someone has changed the original outside light for a PIR light, put the switched live in with the permanent live. The PIR has now developed a fault and is permanently on.
He said he was going to report back a week yesterday. He's either a DIYer or maybe an apprentice, without much experience, whose a bit frightened of getting back in touch. Whatever, he shouldn't have been 'finding power using a wire tracker' and needed assistance. I just hope he found some, for his sake and that of his 'client'.
Let us know OP.
Reply to Lighting ring issue in the Lighting Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
brilliant thanks for your support. Lee
