W
watson789
Hi all
Recently purcahsed a property and have fould that the lighting main is just a spur.
Basically what i need to know is will this be a problem in terms of the spur overloading/ tripping (or any other problems!) if i start to add 'fancy light fittings' say 300w per room?
additional info...
* There are 2 spurs 1 for upstairs lighting and 1 for the downstairs lighting
* Each fitting at the minute has a standard 60w bulb hanging from it
* Downstairs has 4 light fittings upstairs has 5 fittings
sorry what i ment was there is 1 cable coming from the fuse box which meets a junction box underneath the floorboards. from this there is a cable going to each light.
Yeah thats fine, if you're going to be changing fittings though i would check your loadings first , just incase the fuse blows or mcb trips
lighting spur
Australia
watson789,
monkeyelectric,
