J
James sparks
Hi All,
Come across some high level lighting that is supplied via 13A plug and sockets on trunking. It's wired in 1.5 singles with a 15A 3036 and each light has a 3A fuse in the plug. Although the protective device is over-rated, is the plug and socket arrangement acceptable? The sockets are not marked with their intended purpose (ie lighting only) but they are way out of reach so nothing else should get plugged in to them and there are only enough for the amount of lights there are.
Thanks for any suggestions
