Lighting wiring hager klik and vitesse plus lcm's | on ElectriciansForums
Discuss Lighting wiring hager klik and vitesse plus lcm's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
senor_fabulous
Chaps does any one have any wiring diagrams for hager lcm's klik roses but especially vitesse plus lcm's as it's doing my head in any help and advice is as always appreciated
Reply to Lighting wiring hager klik and vitesse plus lcm's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
