Lighting wiring, proving neutral | on ElectriciansForums
Discuss Lighting wiring, proving neutral in the Electrical Course Trainees Only area at ElectriciansForums.net
gazdkw82
leicester
So I had a tricky little task today. 2 gang 1 way switch in a small office entrance. Controls 2 lights in this area. Customer wanted a sensor to replace the switch so both lights come on when triggered.
Took the switch off and blimey nothing was identifiable. Blues, blacks, reds, browns ,yellows..... Not a single piece of sleeving in sight.
It took me ages to work out what was what.
However, at one point I was trying to prove if any of the blue/black conductors were actually neutrals or not. I linked out R2+RN and tested at the light fitting. I got a reading, however just for clarity I unlinked and tested R2+RN at the fitting and I still got a reading.
I can only imagine that it is due to the fact neutral and earth are effectively the same thing back at the station.
But even though I solved the wiring and all is working it got me thinking. How do you proove neutrals? R1+RN?
Reply to Lighting wiring, proving neutral in the Electrical Course Trainees Only area at ElectriciansForums.net
